Asus Q400 power problem
Pearcea
Friday 18 December 2015
18 December 2015
18 Dec 2015 à 22:28
xpcman Posts 19528 Registration date Wednesday 8 October 2008 Status Contributor Last seen 15 June 2019 - 19 Dec 2015 à 14:32
- Asus Q400 power problem
- Asus fan xpert 4 download - Download - Cleaning and optimization
- Asus laptop volume buttons not working - Guide
- Asus rog phone 8 pro - Guide
15 June 2019
19 Dec 2015 à 14:32
19 Dec 2015 à 14:32
The plug in the laptop is a weak failure point. The plug and/or the plug's connection to the motherboard can often fail. Sometimes it can be fixed by resoldering. Perhaps a local PC repair shop can do the work for you.
