Write protection problem with my pen drive
mimofaruk
Thursday August 25, 2016
Aug 25, 2016 at 03:49 AM
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 - Aug 25, 2016 at 05:39 AM
- Write protection problem with my pen drive
- How to write ' on keyboard - Guide
- Remove write protection from usb - Guide
- K9 web protection - Download - Networks
- Hp pen drive 64gb - Pen Drive, USB & SD Card Forum
- Google drive photos - Guide
Ambucias
11,166
Click start
then run regedit
go to this directory HKEY_LOCAL_MACHINE\SYSTEM\Currentcontrolset\control\
if you can't find StorageDevicePolicies under control folder
then make some new one. Follow this steps:
step 1:
again and right click control folder
step 2:
select new, then click key and rename the new key #1 folder into
step 3:
right click StorageDevicePolicies folder and select new DWORD(32-bit) Value
for 32-bit Operating System and select new DWORD(64-bit) Value
for 64-bit Operating System
step 4:
rename dword newer folder into WriteProtect, then double click WriteProtect
and change the value data into 0 with hexadecimal base, Then close regedit
step 5:
open my computer and refresh it 5 times without do anything to your usb, and
properly eject your flash drive
step 6:
plug in your usb again into your computer and format it using exfat instead of fat32
Now, you can use your flash drive again.
then run regedit
step 1:
step 2:
step 3:
step 4:
step 5:
step 6:
