CPU is not booting, CPU & SMPS FAN is working, but CPU power lig
Pyxis30
Thursday December 29, 2016
Dec 29, 2016 at 12:54 AM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Dec 29, 2016 at 03:39 AM
- CPU is not booting, CPU & SMPS FAN is working, but CPU power lig
- Quick cpu - Download - Diagnosis and monitoring
- Unpark cpu - Download - Cleaning and optimization
- Wsappx high cpu - Guide
- Fan xpert 4 download - Download - Cleaning and optimization
- Cpu z download - Download - Diagnosis and monitoring
R2D2_WD
155
Hi Pyxis,
It seems that there is a power related issue. Sometimes the power may be enough to run the cooling fans but not enough to boot the system. You need to check the condition of your PSU or try with another one. I suggest you to seek assistance from a technician, because they usually have a lot of power supply and can check if the PC will boot with another one before actually buying a new PSU.
A faulty PSU may cause hardware damage in the future.
Hope this helps
Hope this helps
