STRANGE THING HAPPENS WHEN I PRESS SHIFT OR CONTROL HELP PLEASE
Ask a question yemhasy 3Posts Friday September 15, 2017Registration date September 15, 2017 Last seen - Last answered on Sep 15, 2017 at 12:48 PM by ac3mark
when i press SHIFT OR CTRL i get a strange problem
I will give examples to make it easier to understand
So lets say in a 1 game The Shift button makes you sit down so when i press SHIFT i sit down then stand up then sit down then stand up so it presses more than 1 time and sometimes it works perfectly every 3 times i press shift at least 1 time this thing happens and it happens in every game not only in 1 or 2 games
ok another example for the CTRL problem lets say in a game you need to press ctrl to pull out your sword so i press CTRL sometimes same weird thing happen i pull out the sword then i put it in then i pulled out and sometimes the sword is out and i cant get it back in unless i spam the CTRL
(THE KEYBOARD DSN'T HAVE ANYTHING TO DO WITH IT I TRIED 4 DIFFERENT KEYBOARDS)
these are all examples shift and ctrl problem happens every where not only in games
+0
plus moins
It sounds like it may be stickey keys. Have you looked into sticky keys? Hold down the shift key until the system asks you what are you trying to do. Turn off sticky keys!
Leave a comment
+0
plus moins
its not sticky keys btw
ac3mark 7793Posts Monday June 3, 2013Registration date ModeratorStatus September 22, 2017 Last seen - Sep 15, 2017 at 12:46 PM
Turn off the machine, and clean out the keyboard with a vacuum or canned air!
Reply
Leave a comment
+0
plus moins
i just bought the keyboard and the pc is 1 month old
Leave a comment
+0
plus moins
So it happens regardless if you are playing a game, or using notepad?
Leave a comment
Not a member yet?
