My Macer won't switch on, it has a built in battery
Zama
Updated on Dec 14, 2021 at 07:05 AM
HelpiOS Posts 14319 Registration date Friday October 30, 2015 Status Moderator Last seen April 29, 2024 - Dec 14, 2021 at 07:05 AM
- My Macer won't switch on, it has a built in battery
- Battery reset code - Guide
- How to turn on built-in camera on hp laptop windows 10 - Guide
- How to switch accounts on messenger without password - Facebook Messenger Forum
- Activate bluetooth using wireless switch - Network Forum
HelpiOS
1,888
Updated on Dec 14, 2021 at 07:09 AM
As you've a built in battery, try to unplug the power cable, disconnect all peripheral devices and press and hold the Power button for 15 seconds, then plug back the power cable and try to turn it on.
If this doesn't work, does the laptop start if you plug the power cable? If not, try waiting until the battery is fully charged and try again.
