How to fix the VLC no sound problem on MAC?
Annawatson63
Friday February 26, 2021
Updated on Mar 11, 2023 at 05:19 PM
HelpiOS Posts 14307 Registration date Friday October 30, 2015 Status Moderator Last seen April 19, 2024 - Mar 11, 2023 at 05:17 PM
- How to fix the VLC no sound problem on MAC?
- Vlc zoom - Guide
- Vlc download - Download - Video playback
- Sound picker - Guide
- Vlc equalizer - Guide
HelpiOS
1,890
Open VLC, go to Tools > Preferences and select Audio. Make sure Enable audio is checked and that the output settings are set properly.
If everything is correct, check your Mac's audio settings. Go to Apple Menu > System Settings > Sound. Select Output and make sure the proper audio device is selected.
