Camera problem
ash7680 - Sep 8, 2009 at 01:46 AM
 Blocked Profile - Sep 8, 2009 at 07:32 AM
Hello, i have one problem here..when i opened my camera phone sony ericsson k810i..it can't show image and than.. a few second..give me directions that camera cannot showing image.. it still running and show me for closing and open a gain..but that problems still go on when i follow that directions..
This is may be an error on the mobile,
I will recommend you to reset the phone to factory default settings.
Menu (center button c/b ) > right > down > down > select (c/b) > up (that should get you to master reset) > select (c/b) > down (that should be reset all) > select ( c/b ) > (warning appears) select ( c/b ) > (another warning) select ( c/b ) > and the phone will be reset and re-started
This will reset the phone
