Help! Toshiba monitor & motherboard problems?
Amuto8
Friday January 22, 2010
Jan 23, 2010 at 10:31 AM
nd456 - May 22, 2010 at 07:16 AM
- Help! Toshiba monitor & motherboard problems?
- Motherboard components - Guide
- Toshiba touchpad not working - Guide
Wednesday October 8, 2008
1,826
Jan 23, 2010 at 06:35 PM
You may only need a new "backlight" or "inverter" and not a complete screen. You will need to take the laptop to a repair shop for service.
Hi. Unfortunately these X200's are rubbish. I also have one and all of the major hardware components are failing one after the other. It seems to be a common problem, judging by the comments. Best thing to do would be to cut your losses and buy a new laptop. In this instance it sounds like the computer has burned your graphics card. Throw the whole unit in the bin now because it's just the beginning of your problems.
