- Problem conetecting to wireless
- Verizon wireless activation number - Guide
- Spectrum wireless - Guide
- Best wireless chargers - Guide
- 950m wireless-n mini usb adapter driver - Downloads Forum
Anonymous User
Oct 20, 2011 at 02:37 AM
Did you try deleting your wireless profiles and creating one
Go to start and type
manage wireless profiles and press enter
Remove the existing one and create a new wireless profile
Anonymous User
Oct 20, 2011 at 10:33 AM
Are you using a WPA or WPA2 key?
Vista>> WPA/WPA2 always had issues.
Does those laptops connect without a security ? Did you uncheck MAC authentication.
Oct 20, 2011 at 03:42 AM
Try this but no luck!
Thanks for the advise though.
