Sound problem
coday
Sunday April 28, 2013
Apr 28, 2013 at 02:33 AM
coday Posts 2 Registration date Sunday April 28, 2013 Status Member Last seen April 29, 2013 - Apr 29, 2013 at 01:52 AM
- Sound problem
- Sound picker - Guide
- Fx sound - Download - Other
- Beeping sound pc - Guide
828688_t@1
Tuesday February 5, 2013
Apr 28, 2013 at 04:26 AM
hi dear !
same problem was happened with me earliar....!!
but i got the solution. Actually there is a problem with your
speakers. As you can hear/listen the sound from your headphones
but not without them. i'll suggest you two options:
1. you've to download sound drivers of "Realtek AC'97 driver"
and install it on your system, may this one may resolve your prob.
2. if the drivers not helpful then u need to diagnose your laptop
speakers from hardware technician.
thanks
thanks
coday
Thank you, I appreciate it, I will try both alternatives step by step. grateful,
