LCD Touchscreen Monitor does not work
Shiva
May 1, 2016 at 07:48 AM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - May 1, 2016 at 02:29 PM
- LCD Touchscreen Monitor does not work
- How do you right click on most touchscreen devices - Guide
- Huawei lcd test code - Guide
1,826
I do not recommend a do-it-yourself screen replacement for any laptop. You need a high level of experience to successfully do a replacement. It's best to have a local shop do the work for you.
