Cpu fan running fast 3 minutes and stops
Amol
Updated by Ambucias on 5/01/17 at 04:16 AM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jan 5, 2017 at 03:35 PM
- Cpu fan running fast 3 minutes and stops
- Hitman 3 cheats - Guide
- Psiphon 3 download - Download - VPN
- Fnaf 3 download pc - Download - Horror
- Fnia 3 - Download - Adult games
1,826
It appears you have a hardware problem and the BIOS can not complete the boot process. A PC Tech will need access to the computer to find the exact problem. About the only thing you can try is to run with only one memory module.
