Monitor not power
Friday June 5, 2009
Jun 6, 2009 at 04:53 AM
ste22 Posts 3 Registration date Wednesday April 15, 2009 Status Member Last seen June 6, 2009 - Jun 6, 2009 at 06:53 AM
- Thinkvision monitor cable
- Media test failure check cable - Guide
- Power supply cable types - Guide
- Data communication cable types - Guide
ste22
hi,
it may be due to the fact that the monitor cable is not properly connected to the computer.
remove it and then plug it again.
replace the cable if necessary.
also check if the graphic card is properly plugged in the slot.
