Wireless connection problem
ben - 27 Aug 2009 à 05:07
 Blocked Profile - 27 Aug 2009 à 06:07
i down grade my dell 1525 from Vista to windows XP sp2 my problem now is that connection of my wireless router to my laptor it's not able to browse any web site and there a message on wireless connection icon no valid untitication, signal ok and also if i use the dell wlan utility i can see the available wireless connection but on the windows xp icon wireless connection if you view available wireless connection ther no available wireless connection but on dell wlan utility there is, it show all available wireless connections. so i try to remove dell utility, then try again windows xp wireless connection and view available connection it show, i can connect but not able to browse any internet site and also showing on wireless icon connection no valid untitication
sarbel.vilo Posts 233 Registration date Tuesday 18 November 2008 Status Member Last seen 1 August 2010 31
27 Aug 2009 à 05:55
You have to install the driver compatible with xp my friend...
27 Aug 2009 à 06:07
You will have to install the XP drivers for your laptop,
Please click here to download:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D810&os=WW1&osl=en&catid=&impid=
Download the network drivers and install it
Then restart your computer
