Sound problem
alykes
8 Jan 2010 à 07:25
sarath94087 Posts 5 Registration date Monday 4 January 2010 Status Member Last seen 9 January 2010 - 9 Jan 2010 à 20:55
- Sound problem
- Sound forge free - Download - Audio editing
sarath94087
9 January 2010
8 Jan 2010 à 08:45
8 Jan 2010 à 08:45
hello there,
the settings for sound must have been not changed....
go to control panel.... choose sounds and audio devices.... then undo the mute check box.... then increase the volume as u like.....
then in audio tab choose the sound driver which u installed ..... in the next tab do the same....
if ur facing more problem then pls give more info.....
thanks.....
thanks.....
sarath94087
9 January 2010
9 Jan 2010 à 20:55
9 Jan 2010 à 20:55
hello bro,
give more info about your system hardware... wat speakers ur using...... and wat drivers u installed... wats ur sound card.....
9 Jan 2010 à 06:31
