- Gateway laptop won't charge when plugged in
- How long to charge ps3 controller - Guide
- How to @ in laptop - Guide
- Restore gateway laptop - Guide
- Ipod nano only turns on when plugged in - Monitor Forum
- Overheating laptop - Guide
6 responses
Does the laptop power in without the battery in using the power adapter?
if so, you'll need to replace the battery.
Using the laptop whilst having it on charge can have effects on the battery.
I am having the same problem!!! Ever since I bought this laptop 2 years ago I have had nothing but problems. Very dissapointed. And your right Gateway isnot much Help.
This happened to me with the exact same model. My husband fixed it by wiring an external power plug to the circuit board. I also have to replace the battery within the month as it is also going. It might be cheaper to buy a new laptop with the cost of the batteries! The 2 plugs my husband bought cost $4 at Radio Shack and another $2 for the wire. Good luck
Sep 4, 2011 at 07:06 AM
