System restore problem
hiker25
Tuesday March 23, 2010
Aug 12, 2011 at 02:41 PM
hiker25 Posts 4 Registration date Tuesday March 23, 2010 Status Member Last seen August 12, 2011 - Aug 12, 2011 at 02:55 PM
- System restore problem
- Phison format & restore v3.26.0.0 ✓ - Pen Drive, USB & SD Card Forum
- System restore command prompt - Guide
- Disable system restore - Guide
- Restore deleted whatsapp messages - Home - Apps & Sites
- Recuva restore folder structure - Guide
GM Madman
Friday June 10, 2011
Aug 12, 2011 at 02:53 PM
Greetings, Hiker25!
If you have a Windows Restore CD Put it in and follow the directions or if you want to restore to the previous point follow this:
Click Start>> All Program>> Accessories>> System Tools>> System Restore
That's all I can give you!
Good Luck!
Good Luck!
hiker25
Thanks ..there was no cd ..and I can't get i screen with the orange screen i pressed esp but nothing hapens.
