Power on problem
preetomborthakur
Tuesday February 12, 2013
Feb 12, 2013 at 08:19 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Feb 12, 2013 at 10:04 AM
- Power on problem
- How to turn off power saving mode - Guide
69
Hi preetomborthakur,
This might happen because of POST (Power On Self Test) failure or some failure in Video chip or some other power sub-system failure. It is undetermined from the symptoms you have mentioned as to what is causing the problem. Blinking power light can be an indicator however, this can be determined only if the Exact System Model Number of your Toshiba Laptop is known. Please reply with the Exact System Model Number of your Toshiba Laptop so that I can try finding a fix for the issue. Also check if there are any other symptoms such as beep codes. Further, you can try these basic steps and check if this fixes the problem:
1. Remove AC Adapter and battery from the computer.
2. Remove any External peripherals from the machine.
3. Press and hold the power button for 10-15 seconds.
4. Re-connect the AC Adapter only and try to power on the computer.
5. Check if any difference is observed.
Please do write back to us.
