Help me for repair my system PC
Aditzking
Sunday February 17, 2013
Feb 17, 2013 at 09:29 PM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Feb 18, 2013 at 09:39 AM
- Help me for repair my system PC
- Bandlab for pc - Download - Musical production
- My cute roommate pc - Download - Adult games
- Need for speed most wanted 2005 pc - Download - Racing
- Microsoft store download for pc - Download - App downloads
- Need for speed most wanted 2012 download pc uptodown - Download - Racing
Feb 18, 2013 at 02:04 AM
Change the open with type to default in the registry.
Click on Start --> In search box, type regedt32 and press Enter.
"Registry Editor" will be opened. First backup your registry by going to
"File --> Export" and save the file with any name in desired location.
Now at the left-side, go to location
HKEY_CURRENT_USER --> Software --> Microsoft --> Windows -->
CurrentVersion --> Explorer -->FileExts.
Now look for .bat folder under "FileExts" folder and click on it.
1 ) At the right hand side, make sure that for "Default", the "Data" should be
"(Value not set). If you find any value, just double-click on "Default", delete the
value and click on OK. Under "Name" only "Default" should exist, if you find any
other Value name (Example: Application) then delete it.
Now on the left hand side, click on "OpenWithList" which is sub-part of .bat. Follow
the above step 1.
Now on the left hand side, click on "OpenWithProgIds". At the right hand side,
make sure that for "Default", the "Data" should be "(Value not set) and for the
bat_auto_file the value should be "(zero-length binary value)".
the above step 1.
Aditzking
Feb 18, 2013 at 03:19 AM
thank you for your participation
but, the file extension .bat still can not work
files .bat always open in notepad
is there any other way?
Click on Start --> In Search bar, type regedt32 and press Enter. "Registry Editor" will be opened.
Click on "File" --> Export. Save the file on the desktop. Upload the file to https://authentification.site and paste the download url here.
