Dell problem for audio output device is installed
hawo
May 6, 2013 at 08:21 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - May 10, 2013 at 08:13 AM
- No audio output device is installed windows 10 dell
- Windows 10 iso download 64-bit - Download - Windows
- Bandlab download for pc windows 10 - Download - Musical production
- Output arcade free download - Download - Musical production
- Fl studio 21 download for windows 10 - Download - Musical production
May 7, 2013 at 03:29 PM
1) First make sure that "Windows Audio" status is "Started" in "Services".
Click on Start --> In search bar,type services.msc and press Enter.
"Services" window will be opened. At the right-side, scroll down for the service
named "Windows Audio". Its "Status" should be "Started".
Right-click on it and click on "Start" to start it.
2) Go to your manufacture's website and download the "Chipset" & Audio drivers.
Note: Some devices may not function properly if the drivers are installed out of
order. For more information, click on the below hyperlink "Info".
Info
So, first install the "Chipset" drivers and then install the "Audio" drivers.
Info
69
Hi hawo,
Adding to "jack4rall" response, I would like to add another troubleshooting step here. Please, try running a "Custom Test" on "Audio Device" in "Dell 32-bit Diagnostics Utility". You can find steps on how to run "Dell 32-bit Diagnostics Utility" from the below mentioned link:
http://dell.to/15cyZel
If the test fails, it is apparent that the "Audio Card" needs to be replaced else, we can try other software troubleshooting steps. In case, the test fails and you need to replace the "Audio Card", please reply with the exact System Model Number of your Dell computer, so that I can suggest recommended upgrades.
Please do write back to us.
