Asus k52j not powering up, fan at max speed. flashing indicator
Edgaras123 Posts 1 Registration date Monday January 26, 2015 Status Member Last seen January 26, 2015 - Jan 26, 2015 at 06:48 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jan 27, 2015 at 03:34 PM
I have a problem I have asus k52j I turned off my loptop and next morning then I starten it. It the screen dont turn on, and the cooling fan] is at max speed. And if I hold power button to turn off loptop its shuts down but starts again by it self, and indikator ligths and power lite bliks, ( like loptop starts and turns off again, and again) I tride unpluged it and hold power buttun for 1 min but its the same.
Sorry for bad gramar, not my native language
plz someone help to me :) thx
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 1,824
This all points to a failed motherboard.
You might try removing the memory modules one at a time. In the hope that it's a simple memory card failure.
