USB Flash Drive Problem
bdsumner
Saturday February 27, 2016
Feb 27, 2016 at 06:37 PM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Apr 5, 2016 at 04:05 AM
- USB Flash Drive Problem
- Usb flash drive tester - Download - Backup and recovery
- Usb 4gb flash drive shortcut - Guide
- Chipgenius usb drive - Download - Diagnosis and monitoring
- Adobe flash drive download - Download - Other
- Snapchat flash not working - Guide
R2D2_WD
155
Feb 29, 2016 at 03:45 AM
Hi bdsumner,
Could you open Disk Management and check if the drive appears with correct file format and if there is some unassigned space. Is the capacity more than 16 GB? I strongly recommend you to check the drive on another PC. If the situation is the same and the recognized size in Disk Management is 1 TB, sadly, there may be an issue with the drive preventing you to use the full capacity. Let me know if there is any progress.
Hope this helps
Hope this helps
Feb 29, 2016 at 08:43 AM
Mar 1, 2016 at 03:10 AM
I am really glad that you are happy with the quality of the WD drives!
Have you checked the flash drive on another PC? It is important to know if the issue comes from the PC ports or from the flash drive, because both assumptions are possible. If the drive appears in Disk Management, try changing the drive letter, right clicking on the drive. If you are trying to format the drive from Disk Management, try doing it through Command Prompt typing the following commands:
Diskpart
List disk
Select disk n (where n is the number of the drive)
Clean
Create partition primary
Format fs=NTFS
Exit
Press Enter after every command.
Please let me know if there is any change.
Mar 31, 2016 at 07:17 PM
Brad
Sorry for responding you a bit late. If formatting the drive completed correctly and all the capacity is correctly recognized by Disk Management, but it is not fully usable, there may be a drive problem. Have you checked the drive on another PC? I strongly recommend you to do it and even try it on another OS. If the issue persists and you have a chance to use the warranty, I recommend you to do so. Were you able to use the whole capacity of the drive when you bought it or this issue persisted since the beginning?
Hope this helps
