Compaq laptop cq58 wont power with or without batteries
johnsonwatts
Friday June 17, 2016
Jun 17, 2016 at 03:24 AM
johnsonwatts Posts 2 Registration date Friday June 17, 2016 Status Member Last seen June 18, 2016 - Jun 18, 2016 at 12:02 AM
- Compaq cq58 battery
- Battery reset code - Guide
- Battery info view - Download - Diagnosis and monitoring
- Motherboard battery replacement - Guide
- Acer aspire 5742 battery - Laptop Forum
It indeed sounds like a short or something. Smell it, does it smell burnt? If the battery works on another laptop, but not that one, then that one is broken!
johnsonwatts
Thank you ac3mark, I did smell it but nothing like burnt I even tried to open the laptop and check all the mthere board and could not find any physical damage or anything burnt. With my little experience i know if its the charger the battery should work since it still has some power inside, also if its the power jack connecting to the board, it should still power from the power botton but non of this work am sure it has to do with the power chip but do not know what to do, I wish there could be a trick to resolve this .
