Laptop dead...drive LED and fan goes off after 2/3 secs
antoniboruah
Thursday February 16, 2017
Updated by antoniboruah on 16/02/17 at 12:52 AM
KY_WD Posts 2053 Registration date Thursday October 23, 2014 Status Member Last seen February 28, 2017 - Feb 16, 2017 at 10:28 AM
- Laptop dead...drive LED and fan goes off after 2/3 secs
- Fan xpert 4 download - Download - Cleaning and optimization
- Psiphon 3 - Download - VPN
- Tentacle locker 2 app store - Download - Adult games
- Left 4 dead 2 download - Download - Shooters
- My cute roommate 2 - Download - Adult games
KY_WD
122
Hello antoniboruah,
The first thing I would do is to pull the charger and the battery out from the laptop. Then I would press the power button and wait for about 30 secs. After that I would try to boot my laptop with only the charger plugged in.
My advice to you, if the warranty of your laptop has expired would be to take out the hard drive and try to connect it to another computer through SATA-USB cable. If your hard drive spins up on a different computer and it is recognized there, but cannot power up on your laptop, then the problem is hiding probably in the power supply unit on your motherboard. While on another PC, I advise you to make a backup of your files just in case that you need to replace the motherboard completely.
You could bring your laptop to a technician to make a test of the power connector and/or the power jack center because they might have got damaged.
Cheers.
Cheers.
