Help with " winfolder lock pro v1.4" tool
dexter3435
Wednesday December 1, 2021
Dec 1, 2021 at 02:58 PM
HelpiOS Posts 14321 Registration date Friday October 30, 2015 Status Moderator Last seen May 3, 2024 - Dec 2, 2021 at 10:08 AM
- Help with " winfolder lock pro v1.4" tool
- Kmspico windows 10 pro - Download - Other
- Adobe premiere pro free download - Download - Video editing
- Logic pro x download - Download - Musical production
- Typing master pro - Download - Education
- Usb debugging enabler tool - Download - Other
dexter3435
Dec 1, 2021 at 02:59 PM
any help guys !!??? i really need these files
HelpiOS
1,886
Did you try renaming that folder in the past after it was locked? Perhaps, the tool has saved this folder with its original name and can no longer recognize it with the new name. If you can remember what the old folder name was, try renaming it.
If that folder has never been renamed, start your PC in Safe mode and try accessing the locked folder. In case it is still locked, try restoring your PC to a restore point prior the installation of the tool.
