NO SOUND HELP....
ankit
Sep 1, 2009 at 09:48 AM
sharpman Posts 1021 Registration date Saturday May 23, 2009 Status Contributor Last seen October 20, 2010 - Sep 1, 2009 at 10:04 AM
- NO SOUND HELP....
- Sound picker - Guide
- Fx sound - Download - Other
- Beeping sound pc - Guide
sharpman
183
ok,
we're gonna need some info.
if you type msinfo32 into the run box (start/run) press enter
click on system summary
in the sumary window on the right hand side copy and paste this infor mation into a reply back to this thread.
in that summary window will be the information for the motherboard manufacture etc. this will enable us to trace the drivers that you require for your system.
hope that is helpful for you.
we await your reply.
