- Memory stick pro duo not reading on computer
- Ps3 not reading discs - Guide
- Kmspico windows 10 pro - Download - Other
- Usb memory stick tester - Download - Backup and recovery
- Adobe premiere pro free download - Download - Video editing
- Blue stick 5 - Download - Android emulators
Hi there, same thing happened to me and It was really frustrating, to a point where I was about to smash my PSP! But don't do that, It wont fix anything... Instead, I will propose you something....
For all those people who have the problem of a PSP stopping to read REAL SONY CARDS, first, make sure that the problem comes from the PSP card reader and not the card. To do so, simply test 2 or 3 different cards in your PSP, and If your reader is "damaged", the orange light will keep on blinking... You can also test these same cards on another psp if you have one in hand. They should work perfectly (if the problem is your psp card reader...).
After making sure that your problem is located in the psp, thats what you will do:
- The problem might simply come from the fact that with allot of use, the pins inside the reader don't touch properly the connection contacts from your cards anymore. At least that's what happened to me, and I believe allot of people had the same problem...
What I simply did was to laminate a little piece of cardboard a little thinner than the card and a little longer, to be able to take it out when you need so. After making that piece, all you have to do is insert it with the card (on the card side that doesn't have pins --> where the sony logo is) and voila, you reader will start reading cards again, just like it always did!
This is a simple, cheap, and working method! No need to risk opening the Psp for nothing!!
