How to connect two laptops using LAN cable.
- What are two cables that are used to connect a computer to a printer? (choose two.)
- How to connect 2 laptops using lan cable - Best answers
- What type of cable should be used to connect a laptop directly to another laptop to form an ethernet network? - Best answers
- How to type # in laptop - Guide
- How to connect ps4 to laptop using hdmi cable - Guide
- Lan settings - Guide
- To create a network bridge you must select at least two lan ✓ - Network Forum
- Connecting Two computers, to one printer - Network Forum
9 responses
techman10
Tuesday September 23, 2008
3
Updated on Dec 20, 2018 at 09:57 AM
To Connect Directly without any other devices
This should be all.
- Firstly you need a network crossover cable. Available from most computer stores. This is a special type of cable (not a standard LAN cable)
- Secondly Make sure both computers are on the same workgroup. TO do this Right click on My computer, Properties, go to the Computer Name Tab, See what is written in Workgroup. Change one computer by clicking on change and then type in the name of the other computer in the workgroup space down the bottom. Do not make the computer part of a domain. You want Workgroup.
- This name change will require a computer reboot.
- When both computers are on the same workgroup, we need to set IP Addresses.
- In Control Panel, Open Network Settings.
- Right click on Local Area Connections and select properties.
- Under the heading "This connection uses the following items, Find Internet Protocol (TCP/IP)
- Highlight it, Make sure you don't untick the box, and click on properties
- Under the heading Use the following IP Address ENter in the Following on ONE Computer.
- IP Address 192.168.0.10
- Subnet Mask 255.255.255.0
- Default Gateway LEave Blank
- Under the Heading Obtain DNS Serveraddress automatically
- Set this to Automatic. Don't enter anything in.
- On the second computer Make the IP Address 192.168.0.20
- Everything else the same.
This should be all.
Jan 21, 2009 at 02:18 PM
Feb 1, 2009 at 05:27 AM
