How to connect two laptops using LAN cable in [Solved/Closed]
Pravin - Oct 3, 2008 at 01:34 PM - Latest reply:  Frank
- May 7, 2017 at 07:52 AM
We want to play Age of Empire between two Laptops
How to connect two laptops using LAN cable in Vista? Could you explain us from first step?
Thanks for your support
Pravin
+74
9
1st step:Install lan driver in both laptops from there own methere bord cd.
2nd step:Connect both laptop vis lan wire.
3rd step:Goto startmenu--->Control Panel--->Network Connections.there is a item whose name Local Area Connection
4th step: Right click on Local Area Connection.select properties from menu.
5th step:select General tab,see there is a level name by "The connection uses the following item :".scroll and select Iternet protocol (TCP/IP) and press properties button
6th step:Select Use the following IP address,put ther IP address.its like 192.168.0.1(IP address) and subnet mask is 255.255.255.0 and press ok.after thene press close button.
i think after that work,
but note that ip address are diffrent in both lapto.
Was this answer helpful?
detail information about this topic
guys... just create a home wireless network of laptop... as many as can laptop can b connected... and u can transfer data.. and can play games with each other...
thank u.. this is really good
@zzzassss:
but it ask network password
Thanks so much, the knowledge was a great help for me.
+18
You need a special "crossover" LAN cable - standard LAN (CAT-5) cables are made to plug-in to a router.
brianwhitt77 344 Posts Thursday September 16, 2010Registration date November 19, 2011 Last seen - Sep 17, 2010 at 07:15 AM
+18
Please get to the following address for having the connection completed.
http://ccm.net/faq/342-connecting-two-computers-with-a-usb-cable
Thanks in advance.
GiantLeap 94 Posts Saturday November 29, 2008Registration date December 8, 2008 Last seen - Dec 1, 2008 at 03:50 PM
+11
1) Plug-in your cable to both PCs
2) startup 1st pc's AoE as host and ONLY THEN startup 2nd pc as client
DONT DO ANY IP CHANGES!!! Windows automatically assigns you addresses of homespace that start with 169.x.x.x
dawooddoe 404 Posts Saturday February 21, 2009Registration date November 12, 2010 Last seen - Feb 22, 2009 at 08:37 AM
+5
You can also check out this article that shows you how to connect two computers directly by using crossover cable.
+4
u have network cable it must a cross over cable.i must have a network and the second one will take network from the other laptop it will config it self.
+4
You all are perfectly right but there is another thing you must tell the user that if you are connecting a two laptops ,then in many laptops only modem connection is given and not lan connection so therefore to connect two modem so that we can play multiplayer games and can do data transfer ,you must need a cross lan wire instead of parallel lan wire
+1
my name is not familiar.so i'm having a problem actually I don't classify it as a massive constraint.So my point of interest is I want to know if windows can share files or printers without connecting to the lan.the reason im arising this point is I heard some guys discussing this issue so please put me in the picture.I dont have a problem with my mandriva linux and suse linux interprise.
