No Audio Device or Sound Icon
mreilly615
Friday May 21, 2010
May 21, 2010 at 07:01 AM
Pallab - May 21, 2010 at 07:20 AM
- No Audio Device or Sound Icon
- Dfx audio enhancer - Download - Other
- Yesmovies no sound ✓ - Hardware Forum
These types of problems are common in Dell and Acer laptops. It usually happens due to the corruption of the operating system. Don't worry, just repair your OS. with the CD provided by your manufacturer (if any) or format and reinstall the OS.
Hope this might solve your problem.
NB. You didn't specify if your external sound system needs to be plugged in externally to any power line or not. If it is so, then first check the earthing matter and voltage. There may be chances of power overdrain to the laptop via your sound box.
Thanks and regards
Pallab
Thanks and regards
Pallab
