No sound on monitor speakers using with lapto
dgfl
Feb 3, 2009 at 02:12 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Feb 3, 2009 at 09:23 PM
- No sound on monitor speakers using with lapto
- Sound picker - Guide
- Why is there no sound on my tv when connected to the laptop with hdmi windows 11 - Guide
- Fx sound - Download - Other
1,826
You connected a audio input plug from the monitor to the earphone jack in the laptop?
If you remove the plug from the laptop does sound then come from the laptop?
Can you plug another source (radio - ipod etc) into the monitor to test the sound?
Is there a volume control knob on the monitor with an on/off switch?
I hope some of these questions help. Good Luck
