Problem in opening the contents in control panel
danielcliff
Wednesday May 8, 2013
May 8, 2013 at 11:23 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - May 9, 2013 at 12:40 PM
- Control panel.{21ec2020-3aea-1069-a2dd-08002b30309d}
- Folder locked and opens to control panel ✓ - Software Forum
- Nvidia control panel download - Download - Other
- Access Control Panel.{21EC2020-3AEA-1069-A2DD-080) ✓ - Windows 10 Forum
- Control panel denies access - Windows Forum
- Cant access my control panel - Windows Forum
May 8, 2013 at 03:00 PM
Click on Start --> In search box, type cmd. When the cmd appears in the
search list, right-click on it and select "Run as administrator".
"Command Prompt" will be opened. Now enter the below command.
sfc /scannow --> Press Enter.
Wait for the process to get completed.
May 9, 2013 at 08:52 AM
first of all thanks jack. i tried your procedure, in that after completion of the process it shows some files are corrupted and are unable to fit ...so what shall i do now...could you please help me jack...?
Do you have "Windows 7 DVD" with you?
