Hardware problem or fails to connect to device hardware
Raj kiran
Aug 17, 2016 at 12:19 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Aug 17, 2016 at 02:19 PM
- Hardware problem or fails to connect to device hardware
- Windows cannot load the device driver for this hardware. the driver may be corrupted or missing. (code 39) - Guide
- Huawei hardware test code - Guide
- Outlook hardware acceleration - Guide
- Hardware acceleration chrome - Guide
1,826
At this point there is nothing that a home user can do. I suggest you return it to Dell for servicing/repair.
