- Battery Problem?????
- Battery reset code - Guide
- Battery info view - Download - Diagnosis and monitoring
- Motherboard battery replacement - Guide
- Mecer z140c battery replacement - Laptop Forum
voltio
Friday March 27, 2009
3
Jun 14, 2009 at 12:59 PM
Hye,
If you can't charge the laptop this due to the charger!!
Your laptop will not charge even with the new charger.
I believe that the issue could be with your battery since the notebook is not taking charge even with your new A/C adapter.
You may try the steps in the below weblink:
http://notebook-solutions.blogspot.com/2009/05/battery-does-not-charge-or-will-not.html
