Dell monitor won't exit power saving mode--changed battery!
phop_2655
Saturday December 12, 2020
Dec 16, 2020 at 01:12 AM
David Webb Posts 3177 Registration date Monday November 25, 2019 Status Member Last seen May 15, 2023 - Dec 17, 2020 at 05:24 AM
- Dell monitor won't wake up from power save
- Dell monitor power save mode problem - Best answers
- How to get dell monitor out of power save mode - Best answers
- Save as pdf office 2007 - Download - Other
- Wake up pc on lan - Guide
- Computer stuck in power save mode - Guide
- Lg monitor power saving mode ✓ - Windows Forum
David Webb
6,928
Hello, besides what Dell suggest to do in their open help forum, I don't know what else to suggest. You've already done what Dell suggest:
If you can get your hands on another monitor to troubleshoot and be sure if its not a problem with your PC that would help. Because you don't want to be buying a new monitor, if the monitor isn't the problem. Or alternatively, to see if its the PC, test your monitor on another PC if possible.
Regards
- Turn the monitor off
- Disconnect every cable (including the power cable) from the rear and side of the monitor
- Press the monitor power button in for 8 seconds
- Reconnect the power cable and a single video cable to the monitor and retest
Regards
