Fans power on, but not booting ???
Beeda - 10 Feb 2010 à 00:30
anjana03 Posts 209 Registration date Tuesday 9 February 2010 Status Member Last seen 26 July 2014 - 11 Feb 2010 à 08:39
I was adding new ram in a P4 machine of my brothers (I know Id rather throw it out than fix it) but anyways it would not take the ram, it is the same specs as the old ram. Pc had 1 512mb stick was upgrading to 2x512mb, both ram sticks work if only one is in at a time, if both are installed I got no video and dvd wont work take one out and everything was back to normal. So I google my problem and went to another site that said to: take out internal battery and install ram put it back in the turn on, if that doesnt work take the battery back out and turn pc back on then off...... After doing that the computer will not boot just the fans come on and 2 led in the front. Any suggestions would be great thanks
4 responses
anjana03 Posts 209 Registration date Tuesday 9 February 2010 Status Member Last seen 26 July 2014 57
10 Feb 2010 à 00:55
If u want to use 2 ram in both slauth once atime we should use same bus speeds ram.if there is diffrent speed it can creat a problem. we face same problem many time. and another we should decided both ram slaut may be good. some time one damage/ short slout may be creat problem. thanks
rickster Posts 111 Registration date Thursday 4 February 2010 Status Member Last seen 11 September 2013 10
10 Feb 2010 à 01:11
enter the bios and choose the right setting for the graphics card, pci/agp it might just be as simple as that.
10 Feb 2010 à 01:47
Hi there,
Whenever changing or adding more Ram to system ,you need to purchase with same frequency,cpu z will help you with frequency and also the maximum ram which will be supported by your system,download it from link below:
https://ccm.net/downloads/security-and-maintenance/4993-cpu-z/
11 Feb 2010 à 08:39
consider- how much capacity ram accept by your computer. 2/ check one ram both slaut one by one .(ram and slaut). we should know different speed ram and different speed processer . we can nt use diffrent speed ram once time . we faced same problem many time in our lab] .it is our experince. good lock u
