How to connect two laptops using LAN cable?
- Connect 2 laptops using lan
- Tentacle locker 2 app store - Download - Adult games
- My cute roommate 2 - Download - Adult games
- Fnia 2 - Download - Adult games
- Laptops overheating - Guide
- Lan settings - Guide
dawooddoe
Saturday February 21, 2009
109
Mar 5, 2010 at 09:48 AM
You can also take a look on this connecting 2 computers directly by using crossover cable article, hope this helps.
Mar 25, 2012 at 11:43 AM
I have a PC (WIN-XP-PRO) and a Laptop (WIN-XP-HOME). In the PC I have an inbuilt lan card and an external lan card. I connected internet (broadband) to the inbuilt lan. I then configured the external lan connection with ip (192.168.0.1) and subnet mask. In the laptop I configured the lan connection with ip (192.168.0.2), subnet mask, default gateway (192.168.0.1) and DNS (192.168.0.1).
I am not able to access internet from the laptop. Also, I am not able to see the other computer (and folders) from the firt and vice-versa.
Please suggest a way forward.
Jun 12, 2012 at 10:57 PM
and check pinging in cmd
if cabel is brocken then no pinging cause
ttl=128 than connection is ok so the fault in youur firwall setting
