Problems with usb mass storage and mmc
- Problems with usb mass storage and mmc
- Hp usb disk storage format tool - Download - Storage
- Windows 98 usb mass storage driver - Download - Drivers
- 1st mass mailer - Download - Email
- Mass effect 2 weapons - Guide
- How to update ps3 with usb - Guide
hi..
thanks for reverting... by the way... thats the issue..i insert my usb device or memory card in my usb port it will appear as normal but instead of my folders.. it appears as shortcut folders and it could not be open..
Jul 30, 2010 at 02:59 PM
If you did not format your flash drive, then check whether the files are not in
hidden mode.
Click on "Start" -->Run-->type cmd and click on OK.
Here I assume your pendrive as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
Note : Replace the letter g with your flash drive letter.
hidden mode.
Enter this command.
