- Volume control not work
- Dshidmini control - Download - Gaming tools
- Defender control - Download - Other
- Samsung volume increase code - Guide
- Asus laptop volume buttons not working - Guide
- Vlc 200 volume - Guide
Sep 6, 2010 at 08:54 AM
Try this 1.
Click on Start --> Run --> Type services.msc and click on OK.
Services windows will be opened. Now scroll down for "Windows Audio".
Make sure its status is "Started". If its not started then to change its status,
double-click on "Windows Audio" --> Set "Startup type:" to "Automatic" and click
on "Start" --> Click on OK.
Good Luck.
Try this 1.
Good Luck.
Hi there,
What is your pc model or motherboard model and series?please provide these required details to give you appropriate driver download link, else this can also be done by the help of driver detective,have it downloaded using the link below:
https://ccm.net/downloads/security-and-maintenance/4873-driver-detective/
