- Sound and graphics problem
- Accelerated graphics port - Guide
- How to choose a graphics card - Guide
- Nvidia graphics driver auto detect - Guide
While formatting your computer, you have actually removed all the drivers on your computer. You should have them reinstalled to get free of the specific trouble that you are facing.
If you are missing the installation cds for the drivers, please make use of the Driver detective application which will automatically trace the drivers that you need.
Kind regards.
Kind regards.
Hi there!
The sound problem comes from the fact that you are missing the sound driver and the movies and games problem from the graphic card's driver.
Thank you.
Thank you.
Hi there,
As mentioned in previous solutions its drivers missing on system resulting it,concerning games you have to install direct x and java,here are links for download:
https://www.xbox.com/en-US/games?xr=shellnav
https://www.java.com/en/download/
