Urgent ...sound problem
romy
Jan 4, 2011 at 01:01 PM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jan 6, 2011 at 06:28 AM
- Urgent ...sound problem
- Sound forge free - Download - Audio editing
Jan 5, 2011 at 06:13 AM
After installation of windows you are suppose to install all the drivers. You can
download the drivers from the manufacture's website and install it.
Or
Let us know your PC brand name and model number.
Or
Jan 5, 2011 at 10:30 PM
see .. i guess i tried everything still it wont work
anyway my cd rom isnt working so i cant install anything ..thats y i need 2 get em from the net
System Information
Time of this report: 1/2/2011, 03:36:32
Machine name: XPHOMESP2
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: Arabic)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 12/20/05 10:37:09 Ver: 08.00.10
Processor: Intel(R) Celeron(R) CPU 2.13GHz
Memory: 480MB RAM
Page File: 426MB used, 487MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
hope u can help :)
thanks
Click on the below link and download the file.
https://ccm.net/downloads/security-and-maintenance/4993-cpu-z/
Extract it --> double-click on CPUZ ---> then click on "Mainboard" tab and let me know the
Manufacturer , Model with rev number, Chipset & Southbridge.
Good luck.
