Power button not responding although motherboard led in on
swtkiller
Wednesday May 15, 2013
May 15, 2013 at 07:31 AM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - May 16, 2013 at 12:36 PM
- Power button not responding although motherboard led in on
- Motherboard description - Guide
- At button - Guide
- Insert button on keyboard - Guide
- Where is the subtitle button on lg remote - Guide
69
Faulty power connections to motherboard and other components can sometimes lead to this situation. Please follow the steps below and check if these steps resolve the issue:
1. Disconnect power cord from the SMPS and any peripherals attached to the computer.
2. Switch off the peripherals and then press and hold the power button for 10-15 seconds. This will remove Flea Power from the computer.
3. Connect the power cord and other necessary peripherals and try to power on the computer. If the computer doesn't power on follow the next step.
4. Repeat steps 1 and 2 then remove the computer cover.
5. Re-seat all the power connections from the Power Supply (or SMPS) to all the components and to the motherboard.
6. Also re-seat the connections from power button to the motherboard.
Note: perform steps 4 to 6 only if you are comfortable to open the computer chassis and work with inner components comfortably else take a technician's help. Also refer to the "Service Manual" of the motherboard for safety instructions and steps to re-seat the power connections from the SMPS.
Do reply with results.
Thanks & Regards
#iworkfordell
Thanks & Regards
#iworkfordell
