Sound problem DEL Inspiron 1110
dave j
Friday August 9, 2013
Aug 9, 2013 at 07:17 PM
dave j Posts 4 Registration date Friday August 9, 2013 Status Member Last seen August 11, 2013 - Aug 11, 2013 at 07:30 PM
- Sound problem DEL Inspiron 1110
- Dell inspiron 1525 wireless not working ✓ - WiFi Forum
- Dell inspiron n5110 keyboard - Keyboard Forum
Wednesday October 8, 2008
Aug 10, 2013 at 06:55 PM
I suggest you try the Microsoft FixIt center.
https://support.microsoft.com/fixit/
You can download a fixit tool for the audio problems
dave j
Aug 11, 2013 at 02:36 PM
I ran this utility and it did not fix the problem. The fix indicated that the device was not found and - check audio device.
Its almost like the OS does not see the audio hardware.
Any other ideas?????
Aug 11, 2013 at 03:39 PM
You might download the "Belarc Advisor " program or see if it can find/identify the sound chip. Just Google it for a download location. If it can't find the chip then you might research USB sound solutions (which might need external speakers).
You might try deleting the audio driver via the Control Panel then restarting the laptop. It should then find the "new" hardware and reinstall all the drivers and registry settings. Sound problems are often the result of installing 3rd party music players - as they sometimes make bad choices when modifying the registry. I would have hoped the Microsoft Fixit program would have found and fixed these registry items.
dave j
Aug 11, 2013 at 06:04 PM
Thank you for the information / advice.
I installed Belarc and ran the analyzer. VERY interesting information.
There were no multimedia entries on the notebook. I ran it on another computer for comparison and found two high definition audio entries.
Does Belarc actually look at the hardware? or is it formatting the registry? If its looking at the hardware, then does this mean that the sound hardware is no longer working? If so, my only alternative would be a USB sound solution.
(The control panel / device manager does not allow the audio driver deletion, as it does not see a driver.)
Dave
Dave
Aug 11, 2013 at 07:08 PM
I think that Belarc scans for hardware much like Windows does when it is installed. The USB adapter can be bought on Amazon and is dirt cheap. This is one that might work for you:
https://www.amazon.com/Sabrent-virtual-External-Adapter-USB-AUDD/dp/B00D69U1B0/ref=sr_1_2?ie=UTF8&qid=1376262367&sr=8-2&keywords=usb+audio+adapter
I have never needed a USB sound card but have used this brand name before.
dave j
Thank you for your help! You are amazing !!
I am going to close this issue.
