My laptop is not coming on after switching on.
Nildo
May 5, 2015 at 11:46 AM
KY_WD Posts 2053 Registration date Thursday October 23, 2014 Status Member Last seen February 28, 2017 - May 6, 2015 at 07:47 AM
- Connex boot from usb
- Headphones not working on laptop - Guide
- How to press # on laptop - Guide
- Where is the insert key on a laptop - Guide
- Why is my laptop keyboard not typing letters - Guide
- Is fl studio free on laptop - Download - Musical production
KY_WD
122
Hello Nildo,
The reason for your laptop not to start up could be due to either failed hard drive or failed power supply. You could try several things:
1. Pull out your hard drive and connect it to another PC via SATA-USB cable to see if it's working there
2. Check the power supply that goes into your RAM slot and SATA, because there might not be enough voltage getting to power up these components.
3. Pull out the RAM stick and make a test to see if it's working.
I think the best option here is to bring your laptop to a technician to make the tests.
Hope this helps.
KY_WD
Hope this helps.
KY_WD
