[HELP]Laptop won't power up/start.
Gabri88
Sunday July 26, 2015
Jul 26, 2015 at 09:53 AM
KY_WD Posts 2053 Registration date Thursday October 23, 2014 Status Member Last seen February 28, 2017 - Jul 28, 2015 at 08:36 AM
- [HELP]Laptop won't power up/start.
- Start survey online free - Download - Horror
- How to @ in laptop - Guide
- Overheating laptop - Guide
KY_WD
122
Hello Gabri88,
When you plug the charger into the jack, can you see the light blinking or just everything remains calm and nothing can be heard from the fan or the hard drive?
If you can't and the warranty of your laptop has expired I suggest you to take out the hard drive and try to connect it to another computer through SATA-USB cable. If your hard drive spins up on a different computer and it is recognized there, but cannot power up on your laptop, then the problem is hiding probably in the power supply unit on your motherboard. You could bring your laptop to a technician to make a test of the power connector and/or the power jack center because they might get damaged. If the HDD doesn't spin at all, anywhere, then it has failed mechanically and needs replacement.
Have you checked the compatibility of your AC adapter and the voltage needed by your laptop? The power may be going to your motherboard but might not be enough to make the drive spin up.
Best of luck.
KY_WD
Best of luck.
KY_WD
