USB flash drive can not be formatted
Anjan
Sep 21, 2015 at 01:32 PM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Sep 23, 2015 at 03:26 AM
- Error in ioctl call usb drive format
- Hp usb disk storage format tool - Download - Storage
- Low level format hard drive - Download - Storage
- Usb flash drive tester - Download - Backup and recovery
- Error network error occurred - Guide
- Chipgenius usb drive - Download - Diagnosis and monitoring
R2D2_WD
155
Hi Anjan,
Have you tried formatting the drive on another PC? I recommend you to do so, because the issue may be OS related. Try using the Diskpart D: /f command from the command prompt.
Another option is to open Device Manager and search for your flash drive. Uninstall it and restart the PC. Plug the drive back in and try to format it.
If the same issue appears even on another PC, sadly there is a chance that the USB flash drive has been damaged.
Hope this helps
Hope this helps
