Lappy charger led light is blinking...
Pavan Kumar Dappili
Oct 31, 2016 at 10:56 AM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Nov 1, 2016 at 06:03 AM
- Lappy charger led light is blinking...
- Coagula light - Download - Other
- Best wireless charger - Guide
- Acer keyboard light - Guide
- Yellow light on touchpad - Guide
- Esc f1 f4 blinking lenovo - Laptop Forum
R2D2_WD
155
Hi Pavan Kumar Dappili,
If your laptop has a removable battery, remove it and disconnect the power cable. Hold the power button for 20 seconds and then reconnect the power cable. Turn on the laptop. Any changes?
If no, then you should test the PC with another power cable. Sometimes cables fail unexpectedly, but getting a new one should fix the problem.
Hope this helps
Hope this helps
