Battery Problems
A
Oct 17, 2009 at 03:58 PM
dancedhall Posts 3056 Registration date Wednesday May 13, 2009 Status Member Last seen March 12, 2010 - Oct 18, 2009 at 03:35 AM
- Battery Problems
- Battery reset code - Guide
- Huawei battery reset code - Guide
- Airtag battery life - Guide
- Can cmos battery cause no display ✓ - Hardware Forum
dancedhall
656
hi there,
your battery is a dead
let the adapter plugged in
shutdown the laptop
remove the battery and est it with a multimeter
if dead then you will have to purchase a new one
shutdown the laptop
