Volume Fn Key does not work :( Please Help!!
smile4kelkel Posts 2 Registration date Wednesday July 21, 2010 Status Member Last seen July 22, 2010 - Jul 21, 2010 at 08:56 PM
Ambucias Posts 47356 Registration date Monday February 1, 2010 Status Moderator Last seen February 15, 2023 - Jul 22, 2010 at 07:12 AM
I have just installed Windows 7 on my Vaio SZ110 and now the volume key doesnt work. I have installed the audio sigmatel driver but my audio still doesnt work. Can someone please help me? Thank YOU!!!!!!!!!!!
Kelly
Jul 22, 2010 at 03:23 AM
Please consider checking whether there is no other function assigned to the specific key.
Thanks in advance.
Ambucias Posts 47356 Registration date Monday February 1, 2010 Status Moderator Last seen February 15, 2023 11,168
Hello Smile
Thank you for your solution and also for your feedback it is very much appreciated. You are a gentleman and a scolar
Jul 22, 2010 at 07:10 AM
Thank you for your reply ralphen. I figured it out. For those who has this same problem, you may want to try to do the same. I just went to device manager and clicked on high definition audio controller and make sure it is enabled. :) Now its working!! The X on the audio is gone :D
-1
