- Kareems Solution for No signal on Monitor
- Driverpack solution download - Download - Cleaning and optimization
- Sceptre monitor no signal entering power save mode - Hardware Forum
- Monitor power light blinking but no display reasons ✓ - Hardware Forum
- Secondary monitor stays in power save mode - Windows 7 Forum
Mar 30, 2011 at 12:30 PM
http://ccm.net/forum/affich-35484-monitor-gets-no-signal-computer-won-t-boot
Mar 30, 2011 at 12:41 PM
Actually doing this removes/drains static and present energy in the machine then when empty you can put back battery and connect adapter to start it.
Mar 30, 2011 at 12:46 PM
Mar 30, 2011 at 01:11 PM
Normally on a desktop pc there you do it to drain the power from power supply capacitors so that when opening cpu you do not get electrocuted.You want experience it?Then power off a desktop pc take a testor remove power cord and put it there ,it will light up .For laptop to be able to drain the remaining energy battery removal is necessary .
Mar 30, 2011 at 01:20 PM
